Netcup - Easter sale
1234568
  • loayloay Member
    @oriend said:
    Does anyone know the way to bulk check available domains to register? I would like to register one for selfhosting stuff, either .de or .eu, but it's a pain to check one by one.
    Strangely enough, OVH's bulk domain search works well:
    https://us.ovh.com/us/order/webcloud/?webCloud/=#/webCloud/domain/select?selection=~()&bulkmode
    Thanked by 1oriend
  • @pbx said:
    @oriend said: Meanwhile namecheap shows available too, and around €5, all the way until checkout, then it says someone else grabbed it meantime.
    Likely a bug on their side. You can use the command whois (in a terminal/shell) to check if a domain is available or not.
    I found the domain order page error’d out on me a lot 2 days ago. If I resubmitted the query a few times it’d finally show a domain a s available. Can’t remember the exact error message I was seeing but, think it was an error and not an ‘unavailable’ prompt.
    FWIW I use name cheap for lookups in the past and never had a name mysteriously disappear.
    Thanked by 1oriend
  • COLBYLICIOUSCOLBYLICIOUS Member
    edited April 2025
    I swear to God @labze has better offers.
    I wish the had some plans with 1tb of nvme storage
    Thanked by 1COLBYLICIOUS
  • TilyTily Member
    I'm going to check it out.
    True, bought the 4 core epyc 9655. Its a beast
  • Netcup have hinted about one last Easter egg; might be this one: https://www.netcup.com/de/server/root-server/rs-1000-g11-se-vie-fe-ost25
    Do you know if the storage is extensible?
    Maybe ask @labze?
    Thanked by 1cainyxues
  • cainyxuescainyxues Member
    edited April 2025
    yup the turin ones have storage upgrade for 2 euros/tb/month -> these are HDDs
    Not the nvme but you can buy block storage for it
    Give ComputeBox a try too.
    I saw the deal, if it had more storage, I'd get it
    edited April 2025
    @strictlyparmesan said: I saw the deal, if it had more storage, I'd get it
    they charge bit extra to increase storage -> of the ssd was like 1.5 euros per 50 gb
    Oh that's real handy I wish that be 1.5 per 100 😂
    That's 30 euros for just 1 TB.
  • itachikonohaitachikonoha Member
    edited April 2025
    @ComputeBox Any chance of 1.5 per 100 GB?
    @remy said:
    @sreekanth850 said:
    @remy said:
    @sreekanth850 said:
    @Motion3549 said:
    @pbx said:
    Same issue for me, it seems like it's a problem with the GeoIP databases.
    Disc speed is much less than my current RS1000 G9.5 which is below
    Yes, new generation of RS have capped IO.
    But that's pretty stable and 4K is higher.
    No real impact for most use cases
    Latency is the most important metric
    So that means, indexing can be slow compared to the old one right? I was planning to use netcup as search engine cluster. But this seems not good.
    I don't think so. Latency of the disk and 4k read / write speed are generally the metric that make the difference.
    And these values are likely to be better with the new generation.
    And it's not even certain that you'll notice anything, because indexes are probably loaded into the ram once anyway...
    Hard to say without benchmarking.
    Practice > theory
    So, a quick glimpse into practice (I of course benchmarked my new RS2000 right away):
    --- Disk IOps (Sync/Direct) ---
    Write seq. [MB/s]: avg 22.96 - min 21.86 (95.2%), max 24.93 (108.6%)
    IOps             : avg 5878.52 - min 5596.79 (95.2%), max 6380.90 (108.5%)
    Which is quite decent (and low spread) but by far not top class.
    I personally wouldn't hesitate to use that VDS for mid to low higher end DB heavy tasks but I would not recommend or use it for a really serious DB larger company job.
    Maybe I'll run my DB benchmark on it (and publish the results).
    I think @Hosteroid bought bigger version of this? Server is great but disk write speeds are shit. they claim nvme but speeds are just like ssd
    Practice > theory
    Any references how to read this metrics? Thank you
  • emperoremperor Member
    edited April 2025
    @vitobotta said: Do you know if the storage is extensible?
    He said : 1 TB Block Storage available for €2/month ($2.5/month) per 1 TB HDD Storage! (Open ticket to request this)
    This one is for the 9665 plans
  • blackjack23blackjack23 Member
    edited April 2025
    VPS 1000 G11 SE OST25 Cost : 5,75 €
    Fr 25. Apr 17:41:35 CEST 2025
    Uptime     : 0 days, 4 hours, 12 minutes
    Processor  : AMD EPYC-Rome Processor
    CPU cores  : 4 @ 1996.250 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 503.8 GiB
    Kernel     : 6.1.0-33-amd64
    VM Type    : KVM
    IPv6 Network Information:
    ISP        : netcup GmbH
    ASN        : AS197540 netcup GmbH
    Host       : NETCUP-GMBH
    Country    : Germany
    Read       | 129.64 MB/s  (32.4k) | 1.37 GB/s    (21.5k)
    Write      | 129.98 MB/s  (32.4k) | 1.38 GB/s    (21.6k)
    Total      | 259.62 MB/s  (64.9k) | 2.76 GB/s    (43.2k)
    Read       | 3.38 GB/s     (6.6k) | 3.45 GB/s     (3.3k)
    Write      | 3.56 GB/s     (6.9k) | 3.68 GB/s     (3.6k)
    Total      | 6.95 GB/s    (13.5k) | 7.14 GB/s     (6.9k)
    Clouvider       | London, UK (10G)          | 2.69 Gbits/sec  | 2.27 Gbits/sec  | 21.2 ms
    Eranium         | Amsterdam, NL (100G)      | 2.72 Gbits/sec  | 2.33 Gbits/sec  | 16.8 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.34 Gbits/sec  | 1.70 Gbits/sec  | 92.1 ms
    Leaseweb        | Singapore, SG (10G)       | 1.52 Gbits/sec  | 1.74 Gbits/sec  | 147 ms
    Clouvider       | Los Angeles, CA, US (10G) | 910 Mbits/sec   | 380 Mbits/sec   | 156 ms
    Leaseweb        | NYC, NY, US (10G)         | 2.08 Gbits/sec  | 1.83 Gbits/sec  | 94.3 ms
    Edgoo           | Sao Paulo, BR (1G)        | 1.76 Gbits/sec  | 1.34 Gbits/sec  | 208 ms
    Clouvider       | London, UK (10G)          | 2.66 Gbits/sec  | 2.30 Gbits/sec  | 21.2 ms
    Eranium         | Amsterdam, NL (100G)      | 2.69 Gbits/sec  | 2.29 Gbits/sec  | 17.0 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.52 Gbits/sec  | 2.02 Gbits/sec  | 90.9 ms
    Leaseweb        | Singapore, SG (10G)       | 2.34 Gbits/sec  | 1.68 Gbits/sec  | 147 ms
    Clouvider       | Los Angeles, CA, US (10G) | 1.09 Gbits/sec  | 585 Mbits/sec   | 156 ms
    Leaseweb        | NYC, NY, US (10G)         | 2.39 Gbits/sec  | 2.03 Gbits/sec  | --
    Edgoo           | Sao Paulo, BR (1G)        | 2.15 Gbits/sec  | 890 Mbits/sec   | 208 ms
    Thanked by 1maverick
    With Netcup I have NVME so I would prefer that for performance rather than HDD. I will contact them and ask more info. Is the host https://my.hostbrr.com/order/forms/ or which one is it?
    Yep, thats @labze
    Yep, thats @labze
    Thanks
    edited April 2025
    RS 1000 G11 SE VIE FE OST25 Cost : 8,24 €
    Fr 25. Apr 17:43:07 CEST 2025
    Uptime     : 0 days, 2 hours, 1 minutes
    Processor  : AMD EPYC 9634 84-Core Processor
    CPU cores  : 4 @ 2246.626 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 503.8 GiB
    VM Type    : KVM
    ISP        : netcup GmbH
    Host       : Netcup KVM VIE
    Country    : Austria
    Read       | 226.44 MB/s  (56.6k) | 476.56 MB/s   (7.4k)
    Write      | 227.04 MB/s  (56.7k) | 479.07 MB/s   (7.4k)
    Total      | 453.48 MB/s (113.3k) | 955.63 MB/s  (14.9k)
    Read       | 484.89 MB/s    (947) | 624.09 MB/s    (609)
    Write      | 510.66 MB/s    (997) | 665.66 MB/s    (650)
    Total      | 995.56 MB/s   (1.9k) | 1.28 GB/s     (1.2k)
    Clouvider       | London, UK (10G)          | 2.58 Gbits/sec  | 2.35 Gbits/sec  | 24.9 ms
    Eranium         | Amsterdam, NL (100G)      | 2.57 Gbits/sec  | 2.35 Gbits/sec  | 21.6 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.72 Gbits/sec  | 1.31 Gbits/sec  | 87.3 ms
    Leaseweb        | Singapore, SG (10G)       | 1.03 Gbits/sec  | 1.75 Gbits/sec  | 160 ms
    Clouvider       | Los Angeles, CA, US (10G) | 592 Mbits/sec   | 679 Mbits/sec   | 157 ms
    Leaseweb        | NYC, NY, US (10G)         | 2.45 Gbits/sec  | 2.00 Gbits/sec  | 105 ms
    Edgoo           | Sao Paulo, BR (1G)        | 1.43 Gbits/sec  | 1.27 Gbits/sec  | 214 ms
    Clouvider       | London, UK (10G)          | 1.95 Gbits/sec  | busy            | 24.9 ms
    Eranium         | Amsterdam, NL (100G)      | 2.58 Gbits/sec  | busy            | 21.6 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.54 Gbits/sec  | 2.00 Gbits/sec  | 87.3 ms
    Leaseweb        | Singapore, SG (10G)       | 2.13 Gbits/sec  | 1.80 Gbits/sec  | --
    Clouvider       | Los Angeles, CA, US (10G) | 545 Mbits/sec   | 1.05 Gbits/sec  | 157 ms
    Leaseweb        | NYC, NY, US (10G)         | 2.27 Gbits/sec  | 2.08 Gbits/sec  | 105 ms
    Edgoo           | Sao Paulo, BR (1G)        | 784 Mbits/sec   | 880 Mbits/sec   | 214 ms
    Practice > theory
    The first number (22.96) is the average result of about 10 benchmark runs in multithreaded write sequential mode with a block size of 4 kB and using 4 threads. After that you can see the min. and max. results achieved during all runs as well as what those min and max results are in relation to the avg. result (in percent) or in other words the spread of all results (tighter obviously is desirable/better).
    And the second line shows the IOps achieved, again, avg, min, max, and spread.
  • VPS 2000 G11 SE NUE OST25 Cost: 12,60 €
    Fr 25. Apr 18:26:51 CEST 2025
    Uptime     : 0 days, 0 hours, 4 minutes
    CPU cores  : 8 @ 1996.249 MHz
    RAM        : 15.6 GiB
    Swap       : 0.0 KiB
    Disk       : 1007.8 GiB
    VM Type    : KVM
    ISP        : netcup GmbH
    Host       : NETCUP-GMBH
    Country    : Germany
    Read       | 121.23 MB/s  (30.3k) | 1.30 GB/s    (20.3k)
    Write      | 121.55 MB/s  (30.3k) | 1.31 GB/s    (20.4k)
    Total      | 242.78 MB/s  (60.6k) | 2.61 GB/s    (40.8k)
    Read       | 3.18 GB/s     (6.2k) | 3.17 GB/s     (3.0k)
    Write      | 3.35 GB/s     (6.5k) | 3.38 GB/s     (3.3k)
    Total      | 6.54 GB/s    (12.7k) | 6.55 GB/s     (6.3k)
    Clouvider       | London, UK (10G)          | 2.66 Gbits/sec  | 2.26 Gbits/sec  | 21.2 ms
    Eranium         | Amsterdam, NL (100G)      | 2.71 Gbits/sec  | 2.30 Gbits/sec  | 16.8 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.49 Gbits/sec  | 2.03 Gbits/sec  | 98.0 ms
    Leaseweb        | Singapore, SG (10G)       | 1.42 Gbits/sec  | 1.54 Gbits/sec  | --
    Clouvider       | Los Angeles, CA, US (10G) | 803 Mbits/sec   | 510 Mbits/sec   | 159 ms
    Leaseweb        | NYC, NY, US (10G)         | 2.40 Gbits/sec  | 1.89 Gbits/sec  | --
    Edgoo           | Sao Paulo, BR (1G)        | 2.01 Gbits/sec  | 700 Mbits/sec   | 206 ms
    Clouvider       | London, UK (10G)          | 2.67 Gbits/sec  | 2.25 Gbits/sec  | 21.2 ms
    Eranium         | Amsterdam, NL (100G)      | 2.69 Gbits/sec  | 2.26 Gbits/sec  | 16.7 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.42 Gbits/sec  | 1.86 Gbits/sec  | 97.9 ms
    Leaseweb        | Singapore, SG (10G)       | 1.36 Gbits/sec  | 1.86 Gbits/sec  | 147 ms
    Clouvider       | Los Angeles, CA, US (10G) | 1.08 Gbits/sec  | 547 Mbits/sec   | 159 ms
    Leaseweb        | NYC, NY, US (10G)         | 2.50 Gbits/sec  | 1.75 Gbits/sec  | 94.1 ms
    Edgoo           | Sao Paulo, BR (1G)        | 2.16 Gbits/sec  | 1.07 Gbits/sec  | 206 ms
    Single Core     | 1015
    Multi Core      | 5114
    Full Test       | https://browser.geekbench.com/v6/cpu/11683771
  • HosteroidHosteroid Member, Patron Provider
    Yeah I took RS8000 to migrate some stuff, but storage speeds are terrible... Ticket was opened since yesterday so far I got only 2 responses from them 1 - run FIO and check disk speeds in "Rescue system" even tho there was debian default installed by them without any changes, in rescue fio speeds were even worse, when i provided all details they said my ticket is forwarded to designated department for further handling.. So looks like they are offering sata SSDs as NVMe :neutral:
    Thanked by 2maverick barbaros
  • Anyone registered .eu or .de domain on netcup without EU residence? Also, do they have whois privacy for these domains?
