Shell Script and Curl Help - VPS to Google Drive - I have script need help
rrrrrr Member
Hi Guys,
I found a cool script which do a fantastic job with Curl.. It uploads predefined file to google drive root.
https://gist.github.com/deanet/3427090
so you just type sh s2g.sh and it will upload file to google drive. I made a change
file="$1" So now it read file path from command like sh s2g.sh filename.tar.gz and it uploads that particular file
but now i have two problems..
How can I upload multiple files from same folder like "*.tar.gz" and how can I set a target directory in Google Drive?
Regards
  • nickyzainickyzai Member, Host Rep
    Write a bash script, for loop, and it should get you good.
  • Having the same post twice doesn't help your cause
  • rrrrrr Member
    It was mistake sir! Sorry for that.
  • rrrrrr Member
    https://gist.github.com/rakeshr/11255588
    Here is the script which will let u set a destination folder..
    still puzzle about files loop.. like
    i have 10 files in a folder
    how can I do
    sh s2g.sh filename1.tar.gz
    sh s2g.sh filename2.tar.gz
    Regards
  • blackblack Member
    edited April 2014
    you're passing filenames as arguments. This means you'll need something like
    for file in $* ; do
    #upload $file here
    done
    Or just use this in the directory that you want to upload your files:
    for file in $(ls); do if [ -f $file ]; then sh s2g.sh $file; fi done
    **your s2g.sh must be in the same level of directory that you want to upload.
    **s2g.sh must be executable.
  • rrrrrr Member
    Ok I got almost everything complete.. but thing is that.. whenever I upload file.. it creates new file on Google Drive.
    Can you guys @nickyzai @black please check the following code.. let me know.. what should I do to overwrite the file or a way to delete that file.
    http://pastebin.com/Z2a2yYAq
    Regards
