How to limit maximum download speed per IP/remote connection for Apache?
Atomic7Atomic7 Member
edited January 2014 in Help
What is the best way to limit the maximum download speed per IP/remote connection in Apache to prevent abusers and miscreants from consuming/wasting excessive bandwidth? I share some files on my website and some miscreants are requesting large files again and again just to waste/consume the bandwidth and since the website is hosted on a high speed server, they are consuming significant bandwidth in short time. I have already banned abusive IPs but every day there are different IPs. Can anyone please help me with this?
  • YKMYKM Member
    mod_cband
    Thanked by 1Atomic7
  • jarjar Top Host, Host Rep, Veteran
    mod_bandwidth also
    Thanked by 1Atomic7
  • YKMYKM Member
    I guess you could use iptables assuming you are in linux..
    Thanked by 1Atomic7
  • @YKM said:
    mod_cband
    @jarland said:
    mod_bandwidth also
    Are there any alternatives? AFAIK mod_cband is preferred/has better control options than mod_bandwidth but it can be CPU intensive. And is it compatible with Apache 2.2? I suppose it's not working with Apache 2.4. Is there any other way to achieve this?
    How to achieve this using iptables?
    Atomic7 said: Are there any alternatives? AFAIK mod_cband is preferred/has better control options than mod_bandwidth but it can be CPU intensive. And is it compatible with Apache 2.2? I suppose it's not working with Apache 2.4. Is there any other way to achieve this?
    There's also mod_bw. Truthfully I've never actually done it, I usually have problems more in line with mod_qos territory myself. Found this though:
    http://stackoverflow.com/questions/17009248/limit-bandwidth-per-apache-virtual-host
    Thanked by 1Atomic7
  • YKMYKM Member
    I am more an ipfw person but I found this, hope it helps:
    http://jmuras.com/blog/2012/limit-bandwidth-for-a-service/
    Thanked by 1Atomic7
  • @Atomic7 Litespeed handles this and is compatible with Apache configurations
    Thanked by 1Atomic7
  • jarland said: There's also mod_bw. Truthfully I've never actually done it, I usually have problems more in line with mod_qos territory myself. Found this though:
    Can mod_qos limit the bandwidth usage? Can this be done using iptables? From what I have read, it's called Linux Traffic Shaping and is not that easy nor the best thing to do, iptables aren't meant for such purpose.
    YKM said: I am more an ipfw person but I found this, hope it helps:
    Wouldn't that just throttle the entire connection speed of port 80? I don't want my website to suffer, I just want to throttle the download speed of files.
    MarkTurner said: @Atomic7 Litespeed handles this and is compatible with Apache configurations
    How can this be done in Litespeed?
  • YKMYKM Member
    Atomic7 said: YKM said: I am more an ipfw person but I found this, hope it helps:
    This would throttle port 80 per ip address, it sounds like you have more of DDOS kind of issue with the IP's changing. ?
  • Do such features exist in Apache or can Apache be configured to do this? I am not really keen to replace apache with litespeed. It's not a ddos attack, each download request is valid, but repeated again and again. They are consuming high bandwidth just because of the connection speed.
    YKM said: This would throttle port 80 per ip address, it sounds like you have more of DDOS kind of issue with the IP's changing. ?
    No, it's not a ddos kind of issue, there are hardly 2 or 3 abusive ips per day but the amount of bandwidth they use is quite significant. These are not concurrent connections, these are repeated connections just to consume the bandwidth. The same large files are requested again and again. Looks like mod_cband is the only solution to this.
  • @Atomic7 - I have no idea I stopped using Apache years ago. I was sick of the performance problems, the problems using PHP or Python performance.
    I have used Litespeed on some pretty large projects (200+ servers) and been very happy with Litespeed's performance. Nginx is another one to look at.
    I mentioned Litespeed specifically because it can use Apache configs right off the bat which saves having to change things around, and if you want to revert back to Apache, you just stop Litespeed and start Apache
    Thanked by 2Mark_R Atomic7
  • @MarkTurner said:
    I would have switched to Nginx long back, but held back because of compatibility issues. I'll definitely consider switching to Litespeed. Thanks for recommending it.
  • CentaurCentaur Member
    edited January 2014
    It also looks like some people are just abusing the downloads, so maybe have a captcha before the download and/or generate a special download link that is linked to the IP address.
    But what you wanted to do, is really easy in Nginx http://www.nginxtips.com/how-to-limit-nginx-download-speed/
    Thanked by 1Atomic7
  • I think I have found the reason for this. My solusvm, ifconfig and log analysis tools are showing different bandwidth stats. I suppose this is due to discrepancies in methods used by different bandwidth monitoring tools. http://docs.cpanel.net/twiki/bin/view/11_30/WHMDocs/BandwidthDiscrepancies
    My log analysis tools are showing high bandwidth usage but it's not the actual bandwidth consumed. I think many visitors are using download managers, which is causing this issue. I'll stick to ifconfig for bandwidth monitoring.
