[HELP] Unusual request: Help with Proxmox problems! Urgent
Hey guys,
normally i wouldnt post this here but i feel kinda in need of a solution or atleast a hint where this problems may reside from:
Here is the original thread: https://forum.proxmox.com/threads/test-luks-softraid-10-f2-slow-vm-performance.34395/
Proxmox with VMs (LXC works fine) spawn way too many threads and make CPU 100% on all cores = go nuts. This happens once someone does a lot IO inside the VM.
I've this problem with the default ISO and manual install. Tested on SATA-Raid, Softraid, and SSD-Hardraid, everywhere the same problems.
Can someone please check if you encounter the same?
Appreciated ![]()
Well have you tried with zfs?
No and i dont want to. Libvirt+KVM works fine and when i want something to work i want it to work. If i'd use ZFS because of this would be the same if if i buy a Mercedes because i cant find a BMW right now (and i would never go for Mercedes!)
Do you ask Proxmox about the issue? What do they answer to your ticket?
Never heard of this before. Installed several Proxmox servers for clients, and none of them have complained either. What version of Proxmox are you on?
